concord_05's avatar
concord_05
No power
Getting ready to head South next week. After wintering motor home, left it plugged in and with all slides closed. When I went out today and opened the door, I could see microwave light on but nothing else would work.. Toggled battery connect switch but nothing comes on. Went ahead and started engin without difficulty and started generator but the only thing that would work is the microwave. I'm assuming I need to replace the batteries. We are not real handy at repairing things in the rv but surely we can replace the batteries. Any words of wisdom before we try it. We have an 08 fourwinds05 chateau citation. Can't get to the fuse box with the bedroom slide in. Thanks for any help you can give.
  • Try turning off 120 volt circuit breakers, applying light pressure toward off. Then turn on main breaker if equipped. The turn on branch breakers one at a time.
    Converter if working should apply 12 volt DC power to the system.
    Your batteries could be good but need charging as it sounds like converter is not operating.
