We own a 2005 Bounder DP with the infamous Norcold 1200. Not new to propane fridges as we bought our first unit with a fridge( graduated from an icebox)in 1970. All of our units until 2004 were Dometi...
Thanks Brett: I am going to install 2 fans in the roof area so I will be able to see if FW installed a baffle. I just checked the sidewall clearances and they could not be much tighter.
Ivylog and Dennis: Where did you get the 12 volts for your fans. On the black box I do see 2 outside connections marked Grd 1 and 12 volt DC. 2 heavy wires, probably 12 or 14 feed those connections. I assume that is the primary 12 volt connection.
