Anna_C's avatar
Anna_C
Notorious Yellow Wire
Recently I purchased a 2005 Winnebago Journey model 34H
I wanted to clean & paint the battery trays
Removed the battery's paying close attention to all connections
After replacement several fuses were blown
All 3 radios , thermostat , generator and back up camera .
All have been corrected and now are operational .
With the exception of the dash radio .Which happens to be a Magnadyne M99000
Which is the only item without a fuse . I have pressed the reset button on the face .
Bench tested the radio and it works .
Now it takes 2 , 12 volt sources to operate . A switchable 12V ( red ) and a constant ( yellow )
I have been through & under every thing in this coach
The breaker on the panel in front has current on both sides I can't find any in line fuses .
I will admit I'm having a tough time reading winnebagos wiring schmatic . ( why does wine use so many yellow wires )
With that said is anyone knowledgable with this dilemma HELP please !
