jbrad13
Oct 08, 2014Explorer
oil change
First oil change on my 2014 Ford Triton V-10 on F53 chassis. The manual says "SAE 5W-20 or equivalent". Should I go synthetic or conventional?
10forty2 wrote:othertonka wrote:10forty2 wrote:
With it being that new, I would definitely use what the owner's manual recommends...at least through the warranty period. If you want to switch over to something else after that, then by all means....
For my 1999 model V10, I used synthetic Mobile 1, 5W-30 and the OEM Motorcraft filter for my recent oil change.
Ford recommends 5W x 20, not 5W x 30. Why did you use 5W x 30? Do you Know something that ford does not know? Just curious
Let me check...it may have actually been 5W-20 instead of 5W-30. I was typing from my fragile, elderly memory and not from my service notebook. But either way, the upper viscosity end of 30W isn't too thick to hurt anything and may actually be good in hotter running. The lower end is what is the most concern for that cold engine start. I'll check and correct myself if I used 5W20 instead. Thanks for catching that!
WILDEBILL308 wrote:
The problem with running a oil with higher viscosity than recommended is todays engines are not your fathers engines. The internal tolerances are much tighter than those built 50 years ago. The rod bearings in your V10 Std Size Oil Clearance: 0.0011/0.0023 in. main bearing oil clearance 0.0001 - 0.0018. When you run a higher viscosity oil you don't get proper lubrication.
But you can run what ever you want in your engine I won't have to pay any money for repairs. I would run Mobil 1 0-20 if it was my engine.
Bill
Born To Travel wrote:You could be right, but I would like to say that my last 4 new cars 2 Toyota's, and 2 Honda's both came from the factory with synthetic oil. When I bought my Winnebago motorhome new from the first oil change on, I used synthetic oil. I also use synthetic oil in my Honda CRV, Harley Davidson, Cub Cadet riding lawn mower and my Whitfield Pellet Stove. I use Mobil 1, 5W - 30W Extended Range Synthetic Oil (silver plastic bottle with a gold cap). I also used 5W 30W Synthetic Oil in my Fleetwood Coach, Triton V-10 powered, that I owned in the 90's. I swear by it and wouldn't use any other oil.
I would use conventional as that engine is not broken in yet and the rings and other parts break in better with that type, as synthetic is too "slippery" for the lack of a better word.. Run it for the first 5,000 miles or so and then decide..
