jbrad13
Oct 08, 2014Explorer
oil change
First oil change on my 2014 Ford Triton V-10 on F53 chassis. The manual says "SAE 5W-20 or equivalent". Should I go synthetic or conventional?
WILDEBILL308 wrote:
Well there agene you are wrong Sully. Bearings wearer with use that is why you have to rebuild engines. When they reach a point where they no longer control oil flow they need to be replaced. In the case I posted earlier you would need to replace the main bearings if the oil gap was 0.002. Let me try to explain this a different way for you. If you have a gap of 0.001 and a gap of 0.006 which one would 50 weight oil flow through faster? Now if you were concerned about getting oil through the smaller 0.001 gap wouldn't it make sense to use a 20 wt. oil?
Bill
Heisenberg wrote:
A new V-10, how could you go wrong with what Ford put in it? Wal Mart carries the Motorcraft 5w-20 synthetic blend and filter.
Sully2 wrote:WILDEBILL308 wrote:427435 wrote:WILDEBILL308 wrote:
The problem with running a oil with higher viscosity than recommended is todays engines are not your fathers engines. The internal tolerances are much tighter than those built 50 years ago. The rod bearings in your V10 Std Size Oil Clearance: 0.0011/0.0023 in. main bearing oil clearance 0.0001 - 0.0018. When you run a higher viscosity oil you don't get proper lubrication.
But you can run what ever you want in your engine I won't have to pay any money for repairs. I would run Mobil 1 0-20 if it was my engine.
Bill
Like many others, you are confusing reduced tolerances with reduced clearances. The minimum clearance that a certain bearing will successfully run at has not changed. But with tighter tolerances, more bearings are closer to that minimum tolerance (nor are there as many bearings that are "loose."
Well actually I do know what I am talking about. In this case we are talking about the oil gap. The bearings will be out of tolerance when they exceed the max dimensions listed. The oil gap is much tighter in newer engines than in the past and require a lower viscosity oil for proper lubrication.
You jump in on this by trying to talk about the manufacturing tolerance.
Bill
REGARDLESS of the thickness of the lube..the BEARINGS remain the size they were machined at!
Bill
Bill
Bill
10forty2 wrote:10forty2 wrote:othertonka wrote:10forty2 wrote:
With it being that new, I would definitely use what the owner's manual recommends...at least through the warranty period. If you want to switch over to something else after that, then by all means....
For my 1999 model V10, I used synthetic Mobile 1, 5W-30 and the OEM Motorcraft filter for my recent oil change.
Ford recommends 5W x 20, not 5W x 30. Why did you use 5W x 30? Do you Know something that ford does not know? Just curious
Let me check...it may have actually been 5W-20 instead of 5W-30. I was typing from my fragile, elderly memory and not from my service notebook. But either way, the upper viscosity end of 30W isn't too thick to hurt anything and may actually be good in hotter running. The lower end is what is the most concern for that cold engine start. I'll check and correct myself if I used 5W20 instead. Thanks for catching that!
Nope...it was 5W-30 Mobile 1 Syn. Didn't really mean to spark off a national incident... ;-)
