- ron_dittmerExplorer III
pnichols wrote:
Most certainly, just like this. In this picture, the full body paint job covers over some of the fiberglass sheathing. The fiberglass sheet overlaps the side wall and is finished off with a rain gutter.
You want the edges of the roof fiberglass piece to be curved downward or "rolled over" the side pieces.
MR MAC wrote:
A type of plastic. It is not ideal because it is not strong even when new. Over time it gets brittle with exposure to the sun. it does not hold up well in a hail storm with big hail or being walked on, especially on older units.
What is a TPO roof - pnicholsExplorer IINot all Class C fiberglass roofs are "the same" - including Winnebago fiberglass roofs.
How the front and rear end caps of the roof fiberglass are designed, mated, and sealed is very important.
Also ... how the edges of the roof fiberglass piece all along it's sides mate with the sidewall fiberglass sheets is very important. i.e. You want the edges of the roof fiberglass piece to be curved downward or "rolled over" the side pieces. Winnebago does not even do it this way on all of their fiberglass roofs. - MR_MACExplorerWhat is a TPO roof
- mlts22Explorer IIAFAIK, Sunseekers have a fiberglass roof. I don't think it is crowned over the edges like the Winnebago, but unlike TPO or EPDM, you are not a puncture from a tree branch away from major water damage.
Next to the one piece Coach House models or a class "B", I would probably say the best roof would be one piece aluminum, crowned over the sides, similar to how Livin' Lite trailers are made.
I am in the market for a motorhome, but biding my time. So far, I do like the Winnebago Fuse. The advantage Fords have over Mercedes is that if something breaks, there is a Ford dealer almost anywhere. Mercedes dealers, especially the subset that handle Sprinters, and the subset of those that have the bays for class "C"s are relatively rare.
My only gripe about the Winnebago Fuse is that if I'm boondocking in the middle of July or August for more than 1-2 days, I either need to carry a hitch mounted cargo rack full of propane cylinders to use with an Extend-A-Stay device, or I haul my 3000 watt Yamaha generator on the rack and a few five gallon gas cans.
Of course, the Ford E-350/E-450 isnt bad either. It is tried and true, and very reliable. No DEF, no DPF, and very simple to maintain. Only real downside I've encountered is that the drive is more fatiguing over a long distance than a Sprinter or Transit. - SBradleyExplorer
ron.dittmer wrote:
I thought Winnebago offered a flavor of models at various price ranges, built using different materials. An entry level model could have a rubber or PTO roof, a high end model will have a better sheet-stock fiberglass roof.
Am I right?
As far as Winnebago being "The Best", I think you will get a lot of opposing views on that one. They might be one of the best for the money spent. But I feel you can spend the same or a little more and get an even better motor home from another manufacture.
But the "BIG" question is: What makes a motor home "The Best"? I agree with others who stated, it's all about the integrity of the structure preventing water from damaging the rig. So once again, here is my long winded take on the subject.
Ron Dittmer
New, used, or well used, when shopping for a conventional class B+ or C, the most important consideration is how it is constructed. This post outlines construction methods which are most affordable and methods that cost more, but are built to hold up much better to the elements and also the punishment of the road.
Some motor home manufactures offer different levels of quality through their various model lines. Instead of providing a list of brands to consider, it is best to identify what "Better" is.
When shopping for a motor home, don't get distracted with what I call "Eye Candy" or "Square Footage". You want to pay close attention to how the house is constructed. Water infiltration is the number one killer of motor homes, rotting them away long before anything is worn out. Once water gets inside, it is like termites. By the time you realize there is a problem, a lot of damage has already occurred. Also consider that mold & mildew can grow inside the walls which then you have a health hazard. My advise focuses on identifying a reliably well sealed motor home.
#1 BEST (Very Expensive, Can Be 1.5 times the cost of Second Best)
NO structural seam work. The brand Coach House is a fine example. It is seamless, made from a mold. The only places where water can leak is cutouts for windows, entry door, roof-top vents & a/c unit, storage compartments & maintenance access, all of which are in areas of very low stress. Because they have a seamless shell, these motor homes have a limited selection of sizes.
#2 SECOND BEST
Common, Affordable, & comes in Many Sizes so this is my main focus
I own an example of this type. My Rig Here manufactured by Phoenix USA.
Made in sections, but assembled in a way that greatly reduces the threat of water damage. Here are the good things you want to look for.
a) Structural Seams Away From Corners
When a motor home is driven, the house bounces, resonates, shakes, and leans countless times, representing a series of extended continuous earthquakes. Corner seams see greater stresses than seams located elsewhere. Corner seams are more easily split, especially when the caulk gets brittle with age & exposure to the sun. One extremely bad bump in the road can instantly breach a corner seam. Seams hold up much better when they are brought in from the corners in lesser stressed areas.
b) A Seamless Over-The-Van Front Cap
A huge bed above the van’s roof is the most vulnerable area of a motor home. No matter how well they are made, that long frontal over-hang resonates when the RV is driven. It is common for seams to split there, most troublesome with age & exposure to the elements. HERE is a more recent example, one of many I have read. The small front aerodynamic cap of a B+ design HERE eliminates the overhang which eliminates most of the resonation, along with most seam work.
There are a few conventional “C” Designs (big over-van bed) where that area is seamless. If you absolutely must have that huge bed, then look for a seamless bucket-like design. Born Free offers a seamless bucket design as seen in This Model. The Itasca Navion Here is another fine example. Some manufactures as of late offer a partial bucket design with fewer seams located in less-stressed areas. Some manufacture models like the Minnie Winnie Premier and the Nexus Phantom utilize a compromising partial bucket design, making it a better choice compared to a fully seamed cab-over bed.
If you plan to accommodate more than 2 people, having that large extra cab-over bed will be extremely useful.
c) A Crowned Roof
Rain and snow melt runs off a crowned roof. A flat roof will sag over time, then water puddles around heavy roof-top items like the a/c unit. Water eventually finds it's way inside after gaskets & caulk have degraded from age, sun, and change in seasons.
d) Rolled-Over-The-Edge seamless Fiberglass Roof Sheathing
A single sheet of fiberglass as shown HERE that rolls over the right & left sides of the roof, down to the wall. The overlapping of fiberglass to the wall provides a good water seal and the fiberglass sheathing holds up better than roofs made of sheet rubber or thin plastic called TPO, which require more attention to keep your RV well protected.
e) A Five Sided Rear Wall Cap
A five sided back wall moves the seams around to the sides to areas of much less stress as seen HERE. The rear wall resembles a shallow rectangular cooking pan standing on it's side. Like the example, some rear wall sections are constructed with an integrated spare tire compartment and rear storage compartment. Not only are they convenience features, but that rear wall/cap offers a solid double-wall for exceptional strength which is more resistant to flexing the adjoining seam work.
Bigger Will Be Weaker
The size & floor plan you select MUST FIRST meet your needs before this consideration.
The bigger the house, the weaker the structure will be. Consider two cardboard boxes made from the exact same corrugated material. The smaller box would naturally be stronger. It will be more resistant to bending, twisting, and other types of flexing. So if you are on the fence between models, the smaller one will be your stronger choice.
Potentially Troublesome Construction
Entry level motor homes are made with seams in corners and finished off with trim, including the massive cab-over bed. Their roof is flat and finished with rubber or TPO. They are most affordable, and come in all sizes. HERE is one such example. If considering this construction type, keep in-mind they require more regular care with bi-annual inspections. Plan to use a caulking gun now and then. When buying a used one, consider that you really don't know how well the previous owner maintained it. Buying new or used, that construction method will be counting on you to be a good non-neglectful owner.
There are also the rare exception of the Lazy Daze which has seam work in the corners, but the substructure and sealing method is of the highest quality that it holds up like a seamless body. It's excellent sectional construction methods are not commonly found in other brands. I am no expert on this, but I'd give it a #1.5 Almost Like Best
About The Chassis
The most popular is the Ford E-Series with the V10 engine. The Sprinter diesel is a popular alternative to the E350 in the smaller sizes. Also within this past year is the recent introduction of the Ford Transit. The GM chassis is not popular, but is a very good choice for the right application. Any of these chassis made since 1998 are real good, new or used. If you plan to tow a car or heavy trailer, be aware that the Sprinter & Transit will be least powered. People who tow with them naturally take it slower.
If considering a current-day “small” class B+ or C motor home, here is a comparison between the two current main contenders, the Sprinter with the V6 diesel engine and the Ford E350 with the V10 gasoline engine.
Advantages Of The Mercedes Sprinter With Diesel Engine
- Offers a 35%-50% improvement in fuel economy over the Ford-V10, when both are loaded and driven identically.
- More ergonomic driver compartment with more leg room.
- Comfort continues with a car-like feel & quiet ride.
- A grander view out the windshield
- Made by Mercedes which people are attracted to.
Advantages Of The Ford E350 with V10 Engine
- Given identical motor homes both brand and model, the Ford is around $13,000 MSRP cheaper
- The Ford V10 engine has 50% more horse power and torque
- The Ford E350 chassis handles 1430 pounds more weight.
- The E350 is able to tow a heavier load.
- The E350 rear axle is significantly wider which translates to better stability.
- In most places traveled, gasoline costs less than diesel fuel
- The Sprinter diesel has limited mechanical service shops around North America
- The Sprinter diesel is typically outfitted with a propane generator. Propane is a critical fuel for RV operations, and generally needs to be rationed when dry camping.
- This Next Point Is Debatable But Still Worth Noting....The V6 Sprinter diesel engine is not allowed to idle for extended periods. This limitation is detrimental when you need a/c but there are generator restrictions or you are dangerously low on propane, or you have a mechanical failure with the generator or roof a/c. The Ford V10 can safely idle for hours on end, heating, cooling, and battery charging, all valuable if you have a baby, pets, or health/respiratory issues.
You decide what your priorities are, and pick the appropriate chassis. There are some really sweet motor homes being built exclusively on the Sprinter chassis, such as the Winnebago Via, View and View Profile. Others like Phoenix USA build their model 2350 and 2400 on both the Sprinter and Ford E350. They will even build it on the heaviest duty E450 upon request for a nominal fee. People who request an E450 for a small motor home, tow heavier things like for example, a multi-horse trailer. You can even special order a E350 & E450 4x4.
There is so much cool stuff offered in recent years on the Sprinter and most recently on the new Ford Transit.
The Ford Transit Chassis
This chassis has the potential to dominate the class B+ & C motor home market in the smaller sizes. According to Ford's website, the Transit DRW chassis is offered in the 156", and 178" wheel base, and is rated as high as 10,360 GVWR. Ford offers a motor home package specific for the RV industry. It's diesel engine compares to the Sprinter in power and fuel economy, but is more affordable and is easily serviced at Ford service centers, just like the E350/E450. The cab has a much lower stance than the Sprinter making it much more friendly to get into and out from for people in their later years. It's more like a mini-van rather than a standard van. The Transit's lower cab also offers roomier over-head bunks that are easier to access.
The Dodge Promaster 3500 Cut-Away Chassis
This front wheel drive chassis is another recent entry in the RV industry. I am concerned over it's lack of load capability as reflected with single free-wheeling rear wheels. I have been reading posts written by new Promaster RV owners stating they are over-weight with just two people, some personal effects and food. They say they can't carry water and never a 3rd person. I would not be comfortable with such a limited load range in a B+ or C. This chassis does seem ideal for the straight "B" motor home market.
The Chevy 3500/4500 Chassis
Unfortunately this chassis is not more popular, primarily because GM sort-of gave up on competing with the Ford E350/E450. It offers more interior comfort than the Ford, but not as much as the Sprinter. It's power & weight ratings are a little less than their Ford counter-parts making them a great chassis for all but the heaviest of class Cs. They are also a little better on fuel consumption. One thing to keep in-mind, if you are counting inches in storing your rig, the Chevy is a little longer than the Ford by a number of inches which was critical for us with our garage as seen HERE with our Ford 2007 E350 rig. That could be the reason why the Chevy has a little more interior driver/passenger leg room.
Engine Power Ratings of Ford, Sprinter, & Chevy
Ford E350/E450 - 6.8L-V10, 305hp, 420ft
Ford Transit Diesel - 3.2L-I5, 185hp, 350ft
Mercedes Sprinter Diesel - 3.0L-V6, 188hp, 325ft
Chevy 3500/4500 - 6.0L-V8, 323hp, 373ft
Dodge Promaster - 3.6L-V6 (GVW only 9,300 pounds)
I agree with most of your points a few exception and personal opinions.
Maintenance on motorhome chassis.
Some not all Ford or Chevy dealerships will work on the chassis if it has an RV conversion sitting on it. I have heard excuses like we don't have a lift that can accommodate or we aren't tooled up for an RV, they just don't want to be bothered.
Maintenance isn't any more or less of a concern between chassis.
When the Transit deisel came out with a Winnabago house I went right down to test drive it. First thing I noticed was the driver possition and comfort, it is ok but to move back into the house you must move the seat back and squeeze past the shifter. The Fuse is much smaller than a View or Navion, all storage compartments are smaller (most of the compartment doors are so small they would be of little use) probably because of the ride height. Lower capacity for water, tanks black and grey. It will be an upgrade to a B but not even comparable to a Navion C. Stamped right on the engine it is built it in S Africa, that surprised me.
It is also not as quiet as a Sprinter. Because of the emissions, DEF required it's computer senor controls are every bit as complicated as a Sprinter. Only time will tell which is more reliable? Still it is another option for those looking for small RV with decent fuel mileage. If you're going to keep an RV long term or travel long distances go with a Diesel, if you're a weekend warrior I would stay with gas. - EMD360ExplorerWinnebago makes a good class C, not best. But competitive with a solid build. They seem to have a history of customer satisfaction, but folks like many RV brands and are often willing to pay higher prices for them. If you are not willing to pay more for a fiberglass roof, which can be the main difference in older models, then just get what will work for your needs and inspect it thoroughly for working appliances, no delamination where the fiberglass sides are coming away from the core, and no leaks. But mine has all three and we still have had a great time with it for several years. I keep working on it and enjoy that so that helps.
- Cousin_Eddie93ExplorerBoth my C's have EPDM. My previous C's roof was a sponge until I installed a new EPDM liner on it. But even then, it suffered some damage after Hurricane Sandy when some branches hit it. The obvious nicks and small puncture wounds were patched, but there were some smaller pin holes not noticed until the following spring. Fortunately, water intrusion was minimal no deep soaking or rot occurred. Had I had a hard shell fiberglass roof, would there have been any holes? Probably not. Given the choice of fiber or rubber, I'd go fiber. However my current rig has floor plan perfect for my family and it came with a price tag I couldn't refuse, despite its roof being rubber.
- BumpyroadExplorer
Am I right?
No that is or at least was incorrect for the motorhomes. AFAIK they were all built with a fiberglass roof.
now since they bought out a firm making their trailers, I believe some of those have TPO or rubber roofs.
bumpy - ron_dittmerExplorer IIII thought Winnebago offered a flavor of models at various price ranges, built using different materials. An entry level model could have a rubber or PTO roof, a high end model will have a better sheet-stock fiberglass roof.
Am I right?
Ron Dittmer
#2 SECOND BEST
c) A Crowned Roof
About The Chassis
38,778 PostsLatest Activity: Jun 10, 2026
