- tatestExplorer IIUnder trees, whether driving mistakes or falling limbs, what rips fabric can still be just a scuff-mark on the heavier Filon sheeting. It is not as heavy as a molded fiberglass cap (e.g. used on upper end Newmars) firmly backed up by being sandwiched with a foam core.
It eventually fades, discolors, but is unlikely to weather through in a human lifetime. Advantage over a comparable aluminum skin is no corrosion of the plastic.
But Winnebago is not the best made rig. It is a rig made to a range of mass markets, with the advantage over some competitors in the same price ranges of partially automated productions and a formal quality management system. "Best made" usually implies "cost is no object" and Winnebago does not build for the market category where prices start at $800K and go well over $2,000,000 so every piece can be the best available, everything carefully hand-crafted. - SCVJeffExplorer
hotbyte wrote:
its really one AND the other
So, longevity vs leakproofness? Definitely can see that as advantage. - rbreakExplorerI had a travel trailer for 8 years that had the epdm rubber roof. It never gave me any trouble, but it did seem vulnerable anytime I was up on the roof to do things like install vent covers or whatever. Always felt like I needed to walk carefully and not accidentally drop a screwdriver or other tool. It also seemed very prone to get that dark maroon colored mold or whatever it was, needed cleaning a lot if you cared about keeping it clean. I have a Winnebago now with a fiberglass roof and like it much better. I can walk around on it and it feels solid and secure, I don't worry as much about accidentally dropping something, I don't worry about hail or low hanging branches damaging it, and it seems like it stays cleaner. But, having had both, I would see having a fiberglass roof as a bonus, but not a necessity. I wouldn't let the roof material determine if I bought the rv or not, other things are more important (floor plan, quality, price, etc.).
 - hotbyteExplorerSo, longevity vs leakproofness? Definitely can see that as advantage.
 - BumpyroadExplorer
hotbyte wrote:
What percent of rubber roofs leak through failure of the rubber vs seal leaks at protrusions/cuts in the roof? Does fiberglass help prevent leaks in seals at protrusions/cuts?
I'm not trying to argue or debate but truly curious...what makes a fiberglass better than rubber?
do a search in this forum on folks wondering what to use to salvage their rubber roof. of course any seams/joints can leak if improperly sealed.
bumpy - hotbyteExplorerWhat percent of rubber roofs leak through failure of the rubber vs seal leaks at protrusions/cuts in the roof? Does fiberglass help prevent leaks in seals at protrusions/cuts?
I'm not trying to argue or debate but truly curious...what makes a fiberglass better than rubber? - BumpyroadExplorerany fiberglass roof will be superior to rubber and probably TPO.
JMHO
bumpy - gboppExplorer
kalynzoo wrote:
I have no intention of placing a second motorhome on the roof. So, whatever.
But, think of all the beer you could carry on the roof. :) - SCVJeffExplorer
azdryheat wrote:
And that is YOUR opinion. I own one that has been relatively problem free but still agree with you. That still doesn't make it true or false
Winnebago is not the best made rig so I discount any other claims made. - azdryheatExplorerWinnebago is not the best made rig so I discount any other claims made.
38,758 PostsLatest Activity: Nov 03, 2025
