Not sure about your particular model but in general Onan's won't start if you have low oil .. check oil level .. if that's OK then disconnect oil pressure sensor (might have to ground) and see if that fixes the problem - if it does then replace oil pressure sensor. . Have you removed spark plug to check for spark?
