DiskDoctr wrote:
wa8yxm wrote:
Fuel filter, can do that kind of thing too. Only it should shut down faster if under load.
The ERROR CODE (refer to your manual for retrival of code) is helpful.
Also the outlet strainer (pick up strainer whatever it's called) inside the fuel tank is another... well.. fuel filter.
Propane generator, according to OP's post ;)
OP- Same results with a Full tank of propane? Is your regulator icy/cold when the genny quits? Any lines icy/very cold?
I have not checked to see if any of the lines are icy or very cold, but I will. Where would be the best location to check, close to the fuel tank or closer to the generator??
Thanks
CarlGeo
