Deano56's avatar
Deano56
Explorer II
Jul 19, 2015
Onan Emerald III 6500
When I bought this motorhome over 2 years ago I was told the generator ran but the tank was too low on gas to run it. At the time it wasn't a deal breaker if it didn't, so I drove it home. Once I put enough fuel in the tank I would push the start button on the dash and it would start right up then make a big belch, then quit. Several time this was the case, so I just left it be since there many other things to work on and the club we belong to has full hookups. The other day I got the bug to work on it so I pulled it out on the slides and tried the same thing, the only thing it would do then was just make the solenoid rattle noise. I looked at all cable ends and cleaned them, retried and still wouldn't start. The next thing was to use a separate battery which I connected and the thing started right up and even powered one of the air conditioners. It runs somewhat rough and I ordered a new muffler being one end is missing. I also will get a carb kit if cleaning the main jet wont clear up the rough running. I tried looking around underneath last night to see if there were and broken cables or dirty connections but, I could find none. I did find that is if I connect the positive cable from the gen to the positive on the chassis battery instead of the block terminal where it was it starts every time. I have no coach batteries hooked up at this time and the cables from them I took out. Do I need the coach batteries for the generator to start or is there a switch I should be moving ?
