sawscjs wrote:
Was wondering if anyone has had problem with onan generator cutting out. While on vacation this summer, at 97º outside when I started the generator, waited 3 minutes for it to load up. Then I turned on the basement heat pump air conditioning. It ran for about 15 minutes cooling the coach , then died. Oil, plugs and air filter are ok. Gas tank was full. Driving down road. Did that 3 times in a row. Always restarted but then died again. Almost like after it got good and hot it cut out. Any ideas ? Thanks.
Just wondering,
What kind of motor home, engine, year, generator model/fuel type etc.? You see, if it's a diesel coach, then it could be a 7.5QD Diesel gen. If that's the case, there's numerous write-ups on generator shut down, prematurely. Need more info.
Scott
