gdbudlong's avatar
gdbudlong
Onboard water system pumps water out the shore input
When I am not connected to a shore water line and I turn on the onboard pump to use the fresh water tank, water streams out of the shoreline input. It does not occur the other way around. In other words, when I am connected to shoreline water it is not leaking into the freshwater tank. Please help. Do I have a bad valve at the shoreline input where it says "Tank Fill" and "Tank Bypass"? Thank you.
