kampy1 wrote:
The Dometic Oasis Elite over the entry door has a motor that is burned out and a replacement is no longer available as Dometic no longer sells or supports this model.
I would like to go to a manual awning as a replacement. My rig is a 2006 Winnebago Vectra. Any experience with this situation or insight into getting a manual replacement. Thanks for any help I can get.
We just replaced the motor on our 2002 Horizon, likely the same awning. They are sort of right. The same motor is not availabe, HOWEVER the tech was able to install a new motor (which fits INSIDE the roller tube) with minor modifications--just screw holes I think.
This is a "Before" pic (you can see why we had to replace it; they don't do well with overhead tree branches :S )
I'll try to get a pic of the new installation in a day or so.
