sailor_lou wrote:
As Brett and others have identified, with a MOHO's general lack of use you are probably better off with the drum setup. To answer your questions, (1) I believe you received the normal expected response and (2) unless I felt I received a severely inferior product, I'd be satisfied and let it pass. In this case, I believe it you are actually better off. Good luck.
Lou
05 Travel Supreme Envoy
I am probably going to take this advice and appreciate the input from others with more experience. I would have felt better if Thor had told me that they did it for a good reason instead of giving me the respose they did.
