ebhairbrain's avatar
ebhairbrain
Power Gear Levelers
I have a 2007 Gulfstream, Voyager. I have no power to the control panel. Checked all fuses and they are hot. Pump working, slides are ok. Have sent an e mail to Power Gear but thought someone might know or had a similar problem. I can't see that there are any in line fuses? I have sitting for four months with jCks down had to manually raise them. Any help would be greatly appreciated.
1 Reply
  • I had a similar problem once. It turns out that there is an inline fuse in the driver's side wheel well. If you look for a small rectangular box, you will find the fuse inside it. You may have to work with the box a little to get it open. Several manufacturers put in a 5 amp fuse, which is too small. I replaced mine with a 10 amp and have had no further problems.
    Good luck.
