The electric step is failing on our motorhome. It's an old front engine gasser, '95 Damon if it makes any difference. Is there a source for replacing the motor and or linkage? Or do I need to bite ...
i replaced the both the motor and gearbox on our 95 Safari with brand new from Amazon the 95 model gear box is no longer made, the new motors, don't connect to old gear box
but the NEW Pair will bolt right into the the old 95 frame
you can buy some internal parts for the gear box little teflon rollers used as a cushion and power transfer coupling but if the gears are broken or the swing arm cam that pushes the step out is broken then you will need to buy a new matched pair
