dougrainer
Oct 15, 2015Nomad
msmith1199 wrote:dougrainer wrote:msmith1199 wrote:DrewE wrote:NoVa RT wrote:
I run the fridge off the battery when traveling, after cooling it down while plugged in at home before leaving. I don't get the preference for propane. Sure, you don't use that much, but you don't use any off the 12V. I figure I'll just use the propane when I run the furnace (mostly cook on an outside grill) and it'll last a very long time.
A large part of the preference comes from the many two-way fridges that don't have a 12V element. The choices are propane or 120VAC power--and if you aren't running the generator while traveling for other reasons such as running an air conditioner, and don't care to buy and install an inverter for fridge use.
In many cases where there is three way power, the 12V element is also significantly less powerful than the burner or the 120V element, so there is less cooling available when running on 12V power. On hot days, that can be an important consideration--you might not be able to maintain sufficiently cool temperatures.
I didn't even know they put three-way refrigerators in motorhomes. I never saw one in the MH's I looked at. Mine is two-way. I have a onboard 2000 watt inverter in my motorhome and the only things not even plugged into that inverter are the A/C's and the Frig. I'm assuming that the reason for this is that National RV decided that the frig was a lot more efficient (?) using propane when 120 volt a/c wasn't available.
No, 3 way refers in the 6 and 8 cubic foot size are not that efficient on 12volt Heat Element to maintain the temp. OEM's including National NEVER, thought about the refer source of power. Some just include the refer 120 plug on the Inverter because they do not want to run extra 120 wiring. Others Free up the refer as they realize there is no reason to run the refer on 120 when you can run on LP. LP or 120 are the same basic BTU's of heat. One is not better than another UNLESS, your 120 line voltage is below 110 or your LP pressure is low. Doug
You start by telling me "No" I assume which was meant to tell me I was wrong. Then you point out in caps that National NEVER thought about the refer source of power. How do you know that a giant motorhome builder NEVER thought about power to the refer? I don't even understand that statement at all. You then go on to state why they power them the way they do including "Others free up the refer as the realize there is no reason to run the refer on 120 when you can run on LP" which is what I said that you implied I was wrong about??? So how did they "realize" this if they never even thought about it?
NO---, I meant your assumption about National was wrong. HOW do I know that? Simple, until they went bankrupt We sold and I serviced National from 1992 on to 2006/07 when they went under and I understood what National did on their design and wiring of their motorhomes. I also have been a RV Tech for 36 years and understand what most RV makers do. For instance, a poster stated to swap the refer 120 cord with the Icemaker cord plug. THAT was usually a Monaco build (I sold and serviced those also until they went under). That means IF you have 2- 120 power cords behind the refer, that means The OEM ordered that Model refer (usually a Norcold 1200) with the optional extra Icemaker plug and Monaco ran the refer on the NON Inverter plug so the Icemaker would work in transit as long as the Inverter turned on, The refer still makes ICE on LP, but requires 120 to operate the Icemaker ejection system. Hence the 2 cords. You can also NOT swap the plugs----Use a dual or triple plug adapter and run both the refer and Icemaker off the inverter plug and leave the other receptacle not used. Doug
38,766 PostsLatest Activity: Jan 10, 2026
