BobboExplorer IISep 21, 2014Did I lube everywhereI just changed the oil in my E450 and ONAN generator. I found 4 zerks on the front end of the E450 to grease. Did I get them all, or are there more than 4? Thanks, Bobbo
indyzmikeExplorerSep 23, 2014Don't forget to check the emergency brake oil reservoir on the tail of the transmission, that is if you have that type of E brake that requires it.
Related ContentPoop water is everywhereWater, water....not everywhere?Jack LubeToilet seal lube?Spiders everywhere
