Community Alumni
Feb 10, 2023Section 5
ENGINE DC CONTROL SYSTEM
Page 23
CIRCUIT CONDITION- FAULT SHUTDOWNS:
The engine has mounted to it a HIGH WATER TEMPERATURE
SWITCH (HWT) and a LOW OIL PRESSURE
SWITCH (LOS). While running, ENGINE
CONTROL circuit board action keeps Terminal 12
Wire 85 energized with battery voltage. Connected in
parallel to (Wire 85) are the LOW OIL PRESSURE
SWITCH (LOS) and HIGH WATER TEMP SWITCH
(HWT). The (LOS) has normally closed contacts.
After start-up, engine oil pressure will open the contacts.
The HWT has normally open contacts. High
coolant temperature will close the contacts.
Should engine water temperature exceed a preset
value, the switch contacts will close. Wire 85 from the
circuit board will connect to ground. Circuit board
action will then initiate a shutdown.
Should engine oil pressure drop below a safe pre-set
On contact closure, Wire 85 will be connected to
ground and circuit board action will initiate an engine
shutdown.
The circuit board has a time delay built into it for the
Wire 85 fault shutdowns. At STARTUP ONLY the circuit
board will wait approximately six (6) seconds
before looking at the Wire 85 fault shutdowns. Once
running after the six (6) second time delay, grounding
Wire 85 through either switch will cause an immediate
shutdown.
The ENGINE CONTROL circuit board also has overspeed
protection. The circuit board senses the AC
output from the stators POWER winding at Terminals
5 & 6 via Wires 22 & 44. This AC voltage and frequency
signal is used indirectly to monitor engine
RPM. If the frequency should increase above a preset
"adjustable" limit, the ENGINE CONTROL circuit
board will cause an immediate shutdown.
From page 23 of the manual. My high water temperature switch went bad.
You can check this at the oil pressure switch where the wire for the temperature switch as well as the oil pressure switch is attached. You can remove the wire from the switches and then start if it continues to run it is the switch.
JimR
Page 23
shutdown.
shutdown.
JimR
Hdcharley24
Aug 12, 2024Explorer
This is exactly what I'm dealing with. Not sure where to go now. As soon as the pre heat button is let go the Gen. Stops which tells me it's not the oil pressure or high temp. Sensor because they have a delay
38,709 PostsLatest Activity: Mar 09, 2025
