RobtS
Apr 10, 2015Explorer
I just installed an inverter in my 2002 36wdd Admiral. In my case it was to run my residential fridge. The unit I bought was a Kisae rm1210.
The inverter sits in the compartment next to the battery compartment. Had to drill through the plastic-tin wall into the batt. compartment for the positive and negative cables to attach to the batteries. The cables were #2 welding cables. [Actually, the pos.in my case, is attached to a lug on the disconnect sw.]
I then drilled up into the bedroom and into the toilet wall, to run the wires to the front. I used a 3/8's piece of plastic tubing,about 10 ft.[Lowes-Home Depot] to fish the wire towards the front. Worked better than I imagined. Usually something crops up that I never anticipated.
I'm sure to get it all the way up front would present a few more problems than my installation.
I also am not sure if the 2002 cofiguration matches your 2005. The folks I purchased my inverter from was Don Rowe, very easy to talk to and very helpful.
http://www.donrowe.com/KISAE-SW1210-Power-Inverter-p/sw1210.htm
BTW---order the remote control too.
38,706 PostsLatest Activity: Feb 01, 2025
