Bob_and_Alice's avatar
Aug 15, 2013
Ready brake system stuck
My ready brake system is stuck and will not operate. I have used penatating oil and dry lube. I even hooked up my car and drove forward to try to loosen it with no luck. Any suggestions would be helpful
    Is it stuck in the engaged position or the brake off position??
    Is it the actuator that is stuck or the cable??
    Do you have the break-away system? If so, did that get pulled?? If so, it is supposed to lock in the brake engaged position. There is a release button that must be pushed to unlock.
  • Have you called ReadyBrake. They are very customer service oriented! (866) 981-5874.
