crasster
Jul 06, 2014Explorer II
Refrigerator issue - "termo fuse" keeps popping
I have a dometic.
On the back side of the fridge (through outdoor panel) there is a tube that gets hot. It has a electric heating element going into it, and on the bottom is where the gas comes in (for flame).
In the center there is some kind of "fuse", with a small button in the middle of two wires on the sides of it. I think it's some kind of thermo fuse or reset.
My symptoms are that the fridge comes on for a short while (10-15 mins) then all power goes off on the fridge. If I go reset that small button on the "fuse" as mentioned above, the power comes back on.
The pipe the fuse is on is getting hot....
I can only assume it is blowing the fuse for being too hot.
The fridge is not getting cold at all the entire time it is on for 10-15 minutes.
Any pointers or suggestions?
(This is in my bounder)
Thank you!
Thank you!
