- LVJ58ExplorerIf replacing shocks on a Ford F53 chassis I would highly recommend the Koni FSD shocks. They're rather expensive but considering how they improved the ride quality on our 2000 coach, I feel they were well worth the cost.
Good luck with your choice of shocks and safe travels.... - wolfe10ExplorerGot a PM from Coffee Grinder. Will post that information here for everyone:
2017 - 5900 miles. I expected it to ride rougher than a diesel but would like to improve it if possible
So, we are dealing with a new chassis/coach.
First question: have you weighed it (individual wheel positions best/axles next best) and set tire pressure according to tire manufacturer's recommendation for that weight? If you are 20 PSI over-inflated, there is no aftermarket device that will give you a smooth ride.
If the front axle is underloaded (lower percent of GAWR on it than the rear axle) move any weight you can forward. A leaf spring that is well-underloaded WILL give a stiff ride.
Next upgrade I would consider would be to replace shocks with Koni FSD's. Yes, they are expensive, but both (yes both) give a softer ride and better handling. That is what two sets of valves in a shock do for you. - wolfe10ExplorerWhat year is your F53?
What condition are the sway bar bushings in?
How many miles on the coach/shocks?
38,773 PostsLatest Activity: Apr 25, 2026
