dougrainer wrote:
valhalla360 wrote:
I wouldn't bother to swap them out if it's just to upgrade but if you are replacing anyway the cost difference should be small, so sure.
As mentioned, two on 30amp is questionable regardless of BTU rating.
The 30amp outlet is actually only rated at 25amp continuous, so while it may or may work, there is a good chance of overheating wires and connections. In a worst case scenario, it could lead to a fire if the breaker doesn't trip.
Please reference any codes or NEC your statement that an RV 30 amp PLUG and 30 POWER CORD is only rated at 25 amp continuous. We are talking RV wiring, not regular home circuits. They have designed 30 amp RV's for over 45 years and in 38 years as a tech, I have NEVER heard the 25 continuous running as it applies to RV's. I have seen and heard it on various forums, but NEVER from an expert, just posters that heard of this from other sources. Doug
It is not directly in the code per say. However there is a section that describes dedicated loads of continuous nature need a supply rated 125% of the load. Or interpreted as continuous load should be not exceed 80% of supply. Continuous load described as 3+ hours.
Granted this does not apply to thermostatic controlled loads such as a water heater or air conditioner at home or in an RV. Still we well know an RV air conditioner can run 12+ hours continuous. Walks like a duck, quacks like a duck..... So it is what it is.
Ever wonder why so many 30 amp plugs get over heated? It is not just worn out connectors.
IMO best to stick with 24 amps max if running continuous.
For the OP... unless you are having cooling issues Iwill suggest staying same or even going to 2x 13.5 units. When shopping do compare amp draw specifications. Look for high efficiency units.
