- joloooteExplorer2006 34' Class'A' liked 67 mph.
- happy-2ExplorerI to have a 2006 37c with a v-10,i find that if i use the cruse control i get best mileage at 65, the tow haul is the best thing going,
- Sfla2Explorer IIIf you get a scan gauge it has a command called lod which is the load % of eng you are using this is from manual
This is a percentage of the maximum power available currently
being generated. In some vehicles it is the maximum
available at the present RPM. it really helps as i stay just under 60% which is my sweet spot, any highr can see MPG fall - carringbExplorer
hanko wrote:
Oh we have 6 gears, where's the other one, I can only find 5
"4th" gear is actually two different ratios, that are not not used sequentially. So yes, the TorqueShift is actually a a 6-speed even though it only uses 5 at a time. - doxiemom11Explorer IIWe drive our V10 at 55-59 mph and average over 9 mpg. Slower is more fuel efficient. No problem driving 65 if you want to though.
- hankoExplorer
Gjac wrote:
In addition to what Mark said your best MPG will be in 6th gear at the lowest RPM that will keep you in 6th gear without constantly downshifting. I am old so I use a vacuum gauge to accomplish this, I'm sure there are computer systems that can do the same thing.
Oh we have 6 gears, where's the other one, I can only find 5 - GjacExplorer IIIIn addition to what Mark said your best MPG will be in 6th gear at the lowest RPM that will keep you in 6th gear without constantly downshifting. I am old so I use a vacuum gauge to accomplish this, I'm sure there are computer systems that can do the same thing.
- 427435ExplorerThe slower you go, the better the mpg. The V10, in my experience, doesn't have a sweet spot--------------or it has a wide range of them.
I normally set the CC at 62 mph on 4 lane highways and 55 on 2 lane roads. - dodge_guyExplorer IIYou will not have an issue keeping it at 65mph. I run mine at about 67 and with the tuner from 5star it can stay in O/D. I avg. 7.5-8.0 mpg. climbing a mountain it will run up to 4300rpm!!! it will have no issue running at that rpm.
- RedJeepExplorerThis has been helpful. With my current truck/trailer I tried to stay about 57 mph. But, I'm hearing I can drive a bit faster without any significant mpg detriment with my new motorhome.
38,766 PostsLatest Activity: Jan 10, 2026
