dougrainer
Feb 11, 2017Nomad
rgatijnet1 wrote:
Wrinkles and bubbles should not exist. I would suspect that the roof was installed by RV mechanics and not by roofers that deal with rubber roofs all of the time. Any wrinkles can hinder drainage and can cause weak areas in the rubber with the flexing. Air gaps mean that the rubber was not embedded in to the adhesive properly and just points to the lack of knowledge with the product. A rubber roof is not rocket science but there is a right way to install it so that you do not have bubbles or wrinkles.
In 37 years as a RV technician, I have NEVER seen an RV roof replaced by a "Roofer" Or non RV roofing company. Wrinkles and some bubbles may be normal. The OP needs to post some pics of the problem. When you use the Dicor sealant, THAT will cause temporary bubbling and possibly wrinkles that shrink in a few weeks. If the installer did NOT use adequate Adhesive that will cause problems. If this is the case(not a big problem), I would NOT want it redone, I would ask for a partial Cash refund of what I paid. Also, if the unit was NOT redecked with wood, that will cause the problem also and if that is the case, I would demand the complete roof be redone and redecked. YOU NEVER REPLACE A EPDM ROOF WITHOUT NEW DECKING. Doug
38,782 PostsLatest Activity: Sep 10, 2026
