John_Joey
Feb 11, 2017Explorer
rgatijnet1 wrote:
..... The point of my post was that RV techs are NOT roofers. As a commercial contractor we installed hundreds of thousands of square feet of EPDM roofing and wrinkles and adhesion bubbles are not acceptible and that most RV techs do not have the skill to do the job right. Commercial roofs are much more challanging than some 8x40 roof on an RV. I have seen brand new EPDM roofs coming out of the RV factory that look exactly like what you would expect when you have an inexperienced installer working to a time schedule. The factory doesn't care and will say that it is covered by their minuscule 2-5 year warranty. Commercial roofs are usually warranted for 20 years with ZERO maintenance requirements. Nobody gets on the roof of a commercial building and washes it and reseals ALL of the penetrations every six months. Commercial buildings are also exposed to the elements 24/7 and able to withstand 130 MPH winds, which I doubt if most RV's will ever experience.
An EPDM roof is a fine product, IF it is installed correctly and not by someone that thinks they can handle it. As they say...a Jack of all trades and a master of none. The fact that this roof was turned over to the customer in this condition says everything about the quality done by that particular RV shop.
When you work with a real roofer who enjoys rubber roofs is when you learn everything you said above is 100% true. On the other hand it is also equally true that just about anyone can lay down a rubber roof. Bubbles and wrinkles may happen if they don't have the gift though.
38,782 PostsLatest Activity: Sep 10, 2026
