4ever16's avatar
4ever16
RV awning str
My strap on the awning is leaving a black mark where it is beating on the home... Have tried Velcro...no luck.What do you use....Thanks, sitting out in Avi Casino KOA now....life is good....
  • fcooper wrote:
    As the awning is retracting and after the strap begins to wind around the roller, I just move the strap to the side so that it winds further up in to the awning. After a little practice, you'll know how much so that only the tip of the loop is visible and won't bang on the rv.
    Fred
    Yes what Fred said..... except when the strap slips off the end of the rod and your awning closes itself, then the strap disappears completely, problem solved ;):B:S
    Fred
    YES! What Fred just said.
  • As the awning is retracting and after the strap begins to wind around the roller, I just move the strap to the side so that it winds further up in to the awning. After a little practice, you'll know how much so that only the tip of the loop is visible and won't bang on the rv.
    Fred
  • Thanks, had thought about using good glue..shortening would work to..Thanks again
  • I shortened mine so all but about an inch rolls up inside the awning.
