- 427435ExplorerMine are 7 years and 40,000 miles old. They're fine but nearing replacement due to wear. I did have a good alignment done at time of installation and insisted that the caster get set to 4-1/2 degrees. I have a theory that reduced caster may cause rivering.
I did move the front tires to a rear position as their outside edges were worn a bit from cornering 10,000 miles ago. - dpscllExplorerHad them 6 years with 25,000 miles and then a front tire blowout. Switched to Michelins 50,000 miles ago and never regretted it.
- spotrotExplorerI don't understand the reason for this thread. If a tire brand had 5% of their tires defective, then over 90% of the owners (those who got good ones) would be pleased with that brand.
So if someone wants to know if a particular brand has very poor quality control, he doesn't care about the 90,000 owners who got good tires. He'd want to know about the 10,000 who got bad tires.
From what I've read on this forum, there are many, many people who have had problems with the G670 tires. Perhaps more than any other brand and model.
I'm in that group. 5 were changed before I'd accept delivery of my new RV. Then, due to rivering wear,the steer tires had to be replaced at about 25k and the rears at about 35k.
So, for the many people who got good G670's, I am sincerely happy for you. - CountryCoachrvExplorerI guess I am one of the fortunate ones, My G670s, 295/80R,22.5, are just over 7 years old and knock on wood, no issues, no rivering and double knock on wood, NO blowouts.
- Don_DonExplorerThank you Topflite for all that good, logical information. Most I have said before as its never anyone's fault on here it always the product that fails. One reason you see so many Goodyears bashers on here as there are so many Goodyears on the road as its the tire of choice for most coach builders . By charts they all speak of I could run 100 lb in the fronts and 90 in the rear on my coach but run 115 in front and 110 in rear. Why do you want to be on the line? Letting pressure out does not improve your ride where it is noticeable. It's all in your head. One thing people don't realize is when you bounce up and down the road, you create more weight pushing down on those tires past what the coach weighs setting still. Don't believe that? Go jump up and down on a scale and you will see what i mean. I will always inflate 10 to 15 percent past what chats say for my load but never past cold pressure max on the tire. Never had a problem.....never.
- Triker33ExplorerHave 7 year old G670 275/70/22.5 with no problem.
In over 40 years of RVing with different typs of RV's. I only have had 2 blow outs. One of them was a front steer. Both were XRV 235/80/22.5 Michelin's
I will never have them for a steer again or rear. Even if they would be $200 a tire cheaper. - topflite51ExplorerTire inflation charts, according to the engineer, are the minimum pressure for the weight listed, his words. Can't remember the last time I saw a MH tire that showed signs of overinflation, but definitely have seen enough of them showing signs of underinflation.
The shock does not have to be wore out, it can simply be undersized for the job. I don't believe a shock has to be wore out to underperform. Have seen plenty of shocks that were wore out that showed no signs of leakage. As to Spartan's recommendation, I would take that with a grain of salt, if it were such a problem for them why is it that they deliver chassis' with GY's on them? If it is a problem and they deliver with GY's than shame on them. Not very responsible on their part is it? They should refuse to do so, bet they won't.
I am glad you are happy with your Mickey's and that they are performing well for you, but in case you haven't noticed there are a lot of people who will not run them for one reason or another. Doesn't mean all of them are bad, it just means that some have had bad luck with them. As I have said before consumers are a funny lot, it is never their fault, it is always the manufacturers. Have a good day. - CbonesExplorer
topflite51 wrote:
That ? was posed to him, and as I recall his response was that tire inflation charts indicated the minimum air pressure for the load. So if you weigh your coach and use the number indicated by the chart you are inflating for the ride, and that is what so many are interested in.
>>>>>Have you ever heard of overinflation? No where on the table does it say minimum pressure. Truck and RV tires publish inflation tables because the load can vary. The manufacturer is publishing the table so that the tire is inflated properly, and the tire contact to the road is proper. If you are carrying a light load, and you inflate the tire to the maximum pressure, only the center of the tire tread is contacting the road, and therefore it is overinflated. Traction will be affected. That is why when the tires are used in a dual configuration, the pressures tend to be lower, cause you have 2 tires to carry the load. The manufacturers spend a lot of time developing these inflation tables. Additionally, when a manufacturer specifies a specific inflation pressure, they are assuming liability for that information. It would behoove you to follow it and not just blindly inflate to maximmum pressure.
As to why one brand does and one brand doesn't do something, probably has something to do with different tire construction and compounds.
>>>>Precisely, and that is whatmakes some tires better than others.
As to what is on high value coaches, has probably more to do with what is spec'd by manufacturer. One thing I do also know about it, what tires come on new MH's has a lot to do with price and availability at the time of production. My parents DS on a Spartan came with GY 670's and he has had no wear problems, but then he hasn't weighed his coach either. For the record he just replaced them with the same, he figured he was on borrowed time as they were going on 8 years. I am sure other top MH's have also had GY's installed. I would even be willing to bet there are other top of the line MH's that came with other brands installed.
As to shops checking one's suspension, I personally haven't been around a shop that can legitamately check out shocks on a 40 foot MH. Tough to do a bounce test unless they have a resident elephant on site. Then again, as he said, the shock does not have to be worn out, it may just not be sufficient to do the job. I seem to recall there was at one time a problem with FSD's and CC's. It seems that the shocks were undersized and they were replaced by either CC or Koni, don't remember which. Don't remember what brand of shock was used either must be my CRS.
>>>>>Generally, if there is no visible signs of leakage, the shock is most probably still good. Additionally, the characteristic rivering issue seems to afflict the Goodyears at a much higher rate than other brands. I guess all those with the rivering issue have bad shocks and don't know how to inflate tires.
But, when all is said and done, you and others can continue to blame the manufacturers for all your problems, it is your tire and it certainly is your money. But one has to wonder why there are so many people out there that have never had the problem. Maybe they haven't weighed their MH's and they have just been lucky. Or maybe they have chosen to ignore conventional wisdom and inflate to the coach sticker or tire pressure marked on the tire. Or is it that they know something others don't? One has to wonder
>>>>>In the end, I have changed nothing else on my coach except the tires. I am following the Michelin inflation tables, and riding on the same shocks. Miraculously my rivering issue has gone away. The switch has worked for me, and I am now a happy camper. I average 20K miles a year, and if something turns up to the contrary I will report back.
:h - topflite51ExplorerThat ? was posed to him, and as I recall his response was that tire inflation charts indicated the minimum air pressure for the load. So if you weigh your coach and use the number indicated by the chart you are inflating for the ride, and that is what so many are interested in.
But, when all is said and done, you and others can continue to blame the manufacturers for all your problems, it is your tire and it certainly is your money. But one has to wonder why there are so many people out there that have never had the problem. Maybe they haven't weighed their MH's and they have just been lucky. Or maybe they have chosen to ignore conventional wisdom and inflate to the coach sticker or tire pressure marked on the tire. Or is it that they know something others don't? One has to wonder:h - CbonesExplorer
topflite51 wrote:
A retired tire engineer indicated to me that the principal cause of rivering was inflation. He said "Too many people inflate for the ride rather than for the load." He then added that the next biggest cause were shocks that were not up to the job. He also said that of course you will never convince the consumer of this, because they know it all. I might add that he never worked for GY.
I think this is all quite funny, as I sold tires for way toooo many years, and the consumer has not changed. One could never convince a consumer that the abnormal wear pattern was caused by their lack of maintenance, it was always the manufacturers fault.
How does your retired tire engineer explain that when an owner has his coach 4 wheel weighed, and adjusts the tire pressure to the manufacturers supplied inflation pressure tables, and has the suspension checked numerous times still has problems with rivering? Then this same owner puts brand M tires on, and all his problems suddenly disappear. Additionally, why do all the higher end coaches seem to come with brand M tires already installed? According to Spartan, their cost difference is approximately $100 per tire when supplying brand M instead of brand G. Over the 3 years of dealing with Goodyear issues, I easily wasted more than the $800 difference! Lastly, it was Spartan that recommended the switch to Michelins.
38,781 PostsLatest Activity: Aug 12, 2026
