Busskipper
Jul 22, 2013Explorer
S-n-L wrote:
Hi all,
For a 45 coach what length of sewer hose would you recommend? Also, what brand of hose and support do you recommend?
Thanks,
Stuart
A lot of interesting info - in thirty plus years of RV'ing I have found that the most used hose is the 6' one that will connect to the connection that is usually set very near the rear tire of the Coach (also the sewer dump) - I have never used anything to elevate the hose -- after more than 30 years in the Utility business -- Water runs to the lowest point, it is really lazy, so when you are ready to leave just flush everything and lift the hose -- then dump the grey water to clean it and move on. I do also carry a 10' extension along with a 20'one(ususlly just stays in the box), these usually dry rot before they have been used much. Good tight connections and smart use of the grey water will make this process much easier.JMHO I have watched every type of glove, system etc, and have found that soap and water really do work.
After many years of playing with and learning from only once did I feel the need for more than I had -- and I just moved the coach to dump the black tank -- Forgot to mention I carry a couple of hose to sewer adapters and 25' of BLACK water hose that I use for grey when needed. 6+10+20 +25 Takes care of everything I need.
After reading you second post I think you have it figured out -- just wait and get it if and when, you need it.
BOL,
38,782 PostsLatest Activity: Aug 11, 2021
