- Dick_BExplorerWe like the Easy Slider three section slide out as sold by CW to provide the proper (1/4 inch drop per foot of length) slope for proper drainage.
- rk911Explorer
JoeGood988 wrote:
The size of your coach has nothing to do with the length of sewer hose. The factor is distance from coach outlet to sewer connection in the ground. There have been times I only needed 5' of hose. Then again, there have been several times I needed 30' of hose. So I carry a 5', 10' & 20' length of hoses...never know. Same way, I carry (2) 25' lengths of water hose and (1) 10' section. Some parks have shared water connections and you have to stretch to connect. Always better to have too much than too little.
precisely. we do the same except I carry one extra 6' length of sewer hose. and yes we have run across at least one instance where we needed all of our sewer hose to reach the sewer connection.
as for support I carry two "accordion" style supports. they compress into just a few inches and take up very little space. - jerseyjimExplorerDoesn't matter what brand..or even what they call "better or best" They all seem to leak after awhile. Pinholes and such. Super-duper at, say Camping World or whatever is available at Wal-Mart. Lasts the same.
I carry a 20 footer and a 10 footer. I've put fittings and the rubber donut on both...and do have other types of fittings that I've purchased over the years. Some campgrounds don't use the rubber donuts. - wittmebaExplorerIf you get the ends right with the bayonet connectors you can use them like extension cords and connect one to another.
These 2 (curved on drive & the one in the trough) will connect together.
http://www.gotnarcosis.com/brucewittmeier/images/DSC01922.JPG - Devonm2012Explorer
rockhillmanor wrote:
I finally ditched carrying the needed 2 sizes of stinky slinky's and broke down and bought a Rhino sewer hose. It is rigid and expands and closes to what ever length you need. And to supplement the hose for an extended stay or uneven ground/obstacles to hook up, I bought a Side Winder.
Both also close/fold to a compact size for ease of storing in bay.
Ahhh, makes the whole sewer experience much nicer. Just sorry I waited so long to make the change.
Not a Rhino fan. They are very expensive and, after two uses, ours leaked like crazy and went in the trash. I do use the hose support and have for many years. For sewer hoses, I have 2 ten foot hoses. Just bought whatever I could find, as has been our experience over the years that they ALL leak after a number of uses so no use wasting a lot of money. Have never had an issue. For water, I have 2 25 foot water hoses. Works for us! - mena661Explorer
X2, we have these.
- Executive45Explorer IIIAs the owner of a 45' coach, I can honestly say the correct length of sewer hose necessary for that size rig, is one that will connect from the sewer connection at the campground to the sewer connection on your rig.....:B:B....if your rig is like mine, you'll have a macerator and it comes with it's own hose and will stretch about 28'. Add a 150' garden hose to that and you're up to about 180'....perfect for that camping spot within 150' of a sewer cleanout or a restroom with flush toilets.....just sayin....Dennis
- lryrob9301Explorer
WoodGlue wrote:
RhinoFlex hose and a SideWinder support like Rockhillmanor has posted above is the best way to go in my opinion.
WoodGlue
X3 - WoodGlueExplorerRhinoFlex hose and a SideWinder support like Rockhillmanor has posted above is the best way to go in my opinion.
WoodGlue - brireneExplorerI have a 20' and a 10'. I'm usually able to use one or the other, and occasionally need both together.Also have the sidewinder support as in rockhillmanor's post, but don't use that often.
