ricelake922 wrote:
Hello. I have a 1996 Monaco Dynasty. We are at a campsite and are plugged into 50 amp service. We have power to the refrigerator and microwave. We do not have any power to the lights in the RV nor at the hot water heater nor air conditioner. We have pushed the reset button on the converter and still no luck. The batteries to the RV are turned on. The DC volts on the heartache monitor are showing 13 but the DC amps are at 0. Please tell us how to fix this please. We are staying here for 4 days. Thank you in advance.
From what you're saying, it's most likely that your 12vdc power is off and the reason you're not getting any lights and some of the 120vac things to operate, like the ac's and water tank, is because the controls for such, is 12vdc, as well. Amp draw will be be obviously at O with no load and the power off. Could be something that needs servicing, like a sw. or relay on the 12vdc mother board, but do double check that your battery switch is on and seeing that your monitor is showing 13vdc at the batteries.
We always a carry a 120vac table lamp, just in case and you should find that your 120vac outlets are still working.
With this statement from lc0338 ...."Just to clarify, the two wires on the two small posts get combined and taped just like the two large ones, right?".......and if you should disconnect the control wiring from the solenoid, they must be separated and insulated, otherwise it will become a direct short and blow a fuse, if the switch should be depressed. Also a good place to check for power, when the sw. is depressed, in troubleshooting and if no power, then one might look for this fuse.
