binary_harbinge's avatar
Aug 19, 2015
Sidewall Tire Repair
Hello all!
I've recently acquired a 1975 Dodge Executive and thus the beginning of my adventure in RVing! The RV is need of some cosmetic work but the engineering is pristine. I'm very excited.
My question is about tires, though. It has 8R19.5 size tires on it and have plenty of thread on them. With exception that on the sidewalls, there is some cracking due to the extreme Las Vegas heat. The tires hold air fine and as I mentioned, practically no tread wear. The previous owner just had it parked and let the sun get to the sides.
I'm trying to avoid investing in a new set of 6 tires. Especially with this oddball side. I've considered using some sealant and/or that Flexseal stuff. I've read good reviews of it and thought it might be a good fix for otherwise good tires.
Any suggestions for this newbie on sidewall tire repair or just tires in general?
Your help is greatly appreciated!
  • EMD360 wrote:
    We have never used the spare, thank goodness, so we updated the old one with a tire that we replaced new.
    Not sure what you are trying to say there but it is a good idea to change the spare at the same time you change the others......because you never know when you might have to put it on at the beginning of a 3 day holiday weekend and use it for a LOT more miles than you planned.
    ALSO....I found that tires mounted under the body and never touched for a long time can be problematic. The tire shop couldn't get mine down; I had to take it to a full service RV shop to have the mounting bolt cut off and replaced with a new one.
  • We just used a spare under our Ford 250 while repairing one of the tires, and the undermount was a bear. Our RV spare is mounted on the back, but still was difficult to remove after sitting there immobile for 10 years or so.
    I think an older spare is just not that big of a risk, but then again I take risks other would not. You never know when you will need a lot of things, but we have roadside service and probably would replace our tire before we used the spare very long. It is truly just an emergency measure. YRMV as they say.
    Then again what is another $250 when you are out spending money right?
  • For the spare. Most tire shops have a good used tire removed by an RVer because its 5 or so years old. They make a nice 1st spare. After that when you change tires every 5 or so years just put the best one on the spare. Then you have a newer spare and you have removed it every few years so it does not rust into place.
