backhoemike's avatar
backhoemike
Slide out rollers on 1995 Newmar london aire
Is there any shortcut tricks to change out the slide out roller myself , unsure if you can let it go out half way and pry up the slideout to gain enough room to replace, these rollers have an orange plastic covering the metal rollers and it is coming off the middle roller and leaving pieces of plastic in the carpet and the holding bracket is scoring the carpet.
  • The only way to change the rollers is to extend about 1/2 way or more and then push the inside top to lift the floor area up. You then wedge wood shims to keep the room tilted back and then replace the rollers. The rollers have a spring load axle pin that you push in to remove and install. Doug
