texasredeye
Jan 19, 2015Explorer
dougrainer wrote:
You just joined. ALWAYS list Year/Brand/Model R V. I have 35 years as a RV tech and have worked on almost ALL slide systems, and what you describe has me puzzled. Can you post a pic of the part? Doug
Sorry, a true noob here. 2007 Gulf Stream Yellowstone Trio 36'. Has me puzzled also. Small part which, by the bent threaded shaft, indicates that at some time the galley slide was retracted with the coach at a severe front down angle or that the ball end was simply extended too far or tightly against the slide which caused the shaft to bend inward and downward. The part is small and rather insignificant, it seems, in the actual operation of the slide. Just irritates me and I would like to replace it.
Don't yet know how to post a pic but if you have an e-mail addy, I can send a rough drawing. I tried taking a pic but the dark corner required a flash but the flash blocked out the details.
38,783 PostsLatest Activity: Sep 23, 2026
