zigzagrv
Jan 20, 2015Explorer
texasredeye wrote:zigzagrv wrote:
It is a guide for the slide and it can be adjusted to make the slide line up properly when opening/closing. I have a Gulfstream (see sig) and replaced one of those guides. Got it thru a Gulfstream dealer.
For more info about your Gulfstream, click HERE
Thanks. I have contacted Gulf Stream. No response as yet. The one I need to replace is not repairable so it must be replaced.
It would probably be easier to find a Gulf Stream dealer locally than to try to deal with the company. They'll probably refer you to a dealer anyway. To keep the slide guide from being damaged in the future, try putting some white grease on the ball and slide where it rolls on. Good luck.
38,783 PostsLatest Activity: Sep 23, 2026
