crasster
May 02, 2017Explorer II
DryCreek wrote:
Sounds like the "Actia Instrument Cluster Failure" I've heard about in the past. There is also an active recall to reflash the module. It looks like remanufactured instrument clusters are available from several sources. They don't seem to be overly expensive for the part (around $150), but if you're not handy with a screwdriver the labor may add up.
Good information. If both problems happened at the same time, it points to electrics.
