Clay_L
May 04, 2017Explorer
This is the recall below. There was also a re-flash available to fix a problem with a intermittent drop out of gauge info but it was not a recall.
"50402-C
Defect Summary: CERTAIN CLASS A MOTOR HOMES BUILT ON WORKHORSE CHASSIS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD (FMVSS) NO. 101, "CONTROLS AND DISPLAY" AND STANDARD NO. 105 "HYDRAULIC AND ELECTRIC BRAKE SYSTEMS." MODELS WITH ACTIA INSTRUMENT CLUSTER, THE INCORRECT SOFTWARE PROGRAMMED INTO THE CLUSTER SUCH THAT CERTAIN WARNINGS ARE NOT DISPLAYED.
Consequence Summary: INCORRECT SOFTWARE MAY NOT HAVE THE ABILITY TO ILLUMINATE WARNING LAMPS INDICATING BRAKE SYSTEM FAILURES. THE STANDARDS REQUIRE DRIVER WARNING WHEN BRAKE FAILURE CODES ARE SET.
Corrective Summary: WORKHORSE IS CONDUCTING THE OWNER NOTIFICATION AND REMEDY FOR THIS CAMPAIGN. OWNERS MAY CONTACT WORKHORSE AT 1-877-294-6773 ."
"50402-C
