Stranger's avatar
Stranger
Splendide wd802m
Never had this happen before. While filling the fresh water tank and pressurizing the entire system, I found that the Washer/Dryer was filling with water.
We have NEVER used the W/D unit. It won't turn on to drain.
Can't open the door because the tub/drum is 1/2 full!
Any ideas?
Thanks.
  • usersmanual wrote:
    the only way that can happen is if its plugged into power and turned on. The door locks when this happens
    If you take a shop vac and open the filter drain and suck the water up u can save a mess.once water is out and power off the door will open
    Don't have 110 to it. Thinking I didn't properly Winterize the W/D and the inlet valve/valves froze. :M :o
  • rgatijnet1 wrote:
    Here is the owner's manual, which you may already have. Manual
    On Winterizing the unit it says to open the drain screen on the bottom right to drain what water remains in the tub.
    Not sure that this is a good idea with a half full drum but perhaps there is some way to get a hose in there and siphon or pump the water out.
    Perhaps if you lower the drain hose, water may run out.
    Thanks, rgatijnet1.
    Yes I have the manual. What I don't have is 110V to the plug for the W/D, either on Gen or Shore.
    I did, however, find two water valves behind the unit. I used my Fiber Optic camera. I've turned those off. Will now run an extension cord to the unit to see If I can get it to spin and drain.
    Later, I will trouble shoot the 110 issue.
    Thanks, again.
    Any ideas?
    Thanks.
  • Here is the owner's manual, which you may already have. Manual
