hanko's avatar
hanko
step issue
I have a 2014 tiffin open road model, went to the barn to check on the coach, and the steps went down fine, when I went to leave I noticed that they hadnt retracted all he way, stuck out maybe two inches. Opened the door and they went down, closed the door, same thing, stuck out a few inches. opened the door and they didn't do anything, Stayed up. didn't have time to fiddle with them. Any ideas. I did climb under and didn't see anything obvious.
  • First thing, Take lots of pictures for reference. Take a hammer and tap the step motor, If that doesn't help Unplug the motor underneath and use a 12v battery (I use a lawn tractor battery)
    Hook-up leads and see if you can activate step ( be sure to keep your fingers out of the step mechanism ) Reverse polarity to open and close. If that doesn't work then knock lynch pin out
    ( It will be tight under tension) Be sure steps are moving freely. Remove motor and take apart gear box look for 3 plastic type plugs. These are window regulator plugs available at Napa etc less than $10.00. I'm assuming you have a car window elec window motor. Generally the motor never goes bad but the plugs get flat spotted. Also assuming steps are regularly lubed. Good luck. Bill
  • Certain Tiffin's had a recall on the coach step brand. Might give em a call for a free replacement
    On edit here is a LINK
  • Is your battery fully charged?
    When was the last time you cleaned and lubed the joints on the steps?
    Check the easy things first.
