The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
Looks like some type of heat-shrink material, but I have never seen anything like it. Find a local cabinet builder and see if they have any suggestions. Is the material very thick?? Another solution would be to call the factory customer service and see what they can tell you. I am thinking about gluing down some of the heat-shrink that is used to winterize boats, then shrink with a heat gun. Other than that, sandpaper and paint.
