The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
Its most likely pvc that is thermo pressed on like the white raised panel doors you see out there. You wont be able to use a solvent based contact adhesive with that if it could be repaired, which it doesn't look like it can be, because of missing pieces
