robertbenita's avatar
robertbenita
threaded opening between Cummins and Allyson Transmission
So last night started getting ready for a trip to Arizona and started the 2001 American Coach Tradition and when I walked outside of the coach, diesel fuel on the ground. As I looked further I noticed the ground looked like the engine just spit it out all over in the area of the engine where it marries up to the transmission. Started wiping down to see if could identify where leaking originated and it is above what looks to be the alternator/generator and couldn't see more because of darkness and now I am at work. Spartan Chassis and it is behind the rear tires almost in the middle but a little more passenger side. Anyone know what might be above or a good mobile diesel mechanic in Corona area of California?
And then as I am wiping everything down I noticed that there is a threaded opening at the bottom of where the engine marries up to the transmission and I think I saw something spinning inside and can't believe that it would just be left uncovered. I should add that there is some kind of loom (unknown if wire or hose) that is nearly blocking my view of this opening. Does this sound right?
And last question relates to an ongoing issue with the refrigerator. Works like a charm on LP. When I set it to auto and am hooked up to electricity, switches to a/c for a while then back to LP and says no a/c. I have found a fuse in the refrigerator compartment (1 amp I think) that restores a/c to fridge, but then blows again not too long later. Any suggestions on where to start?
New to me coach from my father that had a personal mechanic do all his work and now since mine, trying to do most myself. Thanks for any input!
Engine - Cummins® C.8.3 Liter, 315 hp ISC Diesel, Transmission - Allison® 3000 MH 6-Speed Automatic on a Spartan Mountain Master Chassis.
