mtrumpet
Sep 08, 2014Explorer
Tips on replacing Fuel Lift Pump/Cummins 350 ISC?
This past Friday when preparing to leave for a weekend trip, after airing up and hooking up the towed, I noticed a large wet spot under the engine. It was fuel. Upon checking, found that my lift pump was leaking. Got into it and checked for any loose fittings, but nothing. The pump itself is working fine, it's just dumping fuel all over. Therefore, I have to replace the lift pump (a.k.a. ELECTRONIC FUEL TRANSFER PUMP). I picked the new one up at the local Cummins Northeast this morning. $323.00!
Before I get into this, wondering if anyone else here may have replaced yours by yourself? Any tips, advice or anything I should be aware of when removing the old and installing the new pump?
Luckily, this happened right in front of our house, so I just unhooked the towed and pulled right back into the driveway (then cancelled the weekend trip!)
