roscott's avatar
roscott
Tire pressure monitoring systems
Anyone have advice on the best TPMS to purchase? I've seen several brands including Tire Minder, EEZTIRE and TireTech On. I've read reviews but thought I'd solicit actual users from the community before purchasing. Any guidance is appreciated.
  • Seems to be a lot of TST fans. All I've ever owned was my Pressure Pro so I can't compare but it has done the job for me just fine.
  • X8
    Aside from the fact the system works, TST's customer service is outstanding.
  • TST 507 system here. I have 8 sensors and the ones on my 5'er do not require a booster.
  • I too use TST 507 & really love it. I also use it for my trailer tires & it works great without having to boost the signal. Just have to remember that metal valve stems are needed to prevent the sensor from slowly causing issues.
  • I too run the TST system. Second generation..I had the 510 system with non replaceable batteries. Worked flawlessly for two years. Upgraded to the 507 system three years ago and they work as advertised. I'm a satisfied customer...Dennis
  • Most people will tell you they like theirs the best.. I have the TST system and I am satisfied with it.. It has owner replaceable batteries and uses the same batteries that garage door openers use, so you can get them anywhere. Also many large trucking companies are choosing them for their OTR units, so the support base will be around for a while.. http://www.youtube.com/watch?v=5-KsnSUM2F8
