margappy wrote:
Hi, am working on a 2003 Newmar for a friend. When using the automatic hydraulic levelers, is it ok for several of the tires to be off the ground several inches? The levelers are on blocks of wood, and the tires are braced. thanks in advance.
Our coach will raise the front tires off the ground when allowed to level in the auto mode. I usually only hit the on button only once and run the jacks down until the touch the ground and then dump the air. then finish the process by a bubble level by running each jack as required.
I do not like the coach as high as the auto mode will take it.
working under the coach, remember the jacks are not braced side ways. and the rear axel is the only brakes when the air is dumped.
