Francesca Knowles wrote:
Maybe your rig is an exception, but it's my understanding that most levelers/stabilizers aren't designed to support the kind of loads put on them if lifting the rig clear of the ground....nor are those points on the rigframe where the levelers are attached typically designed/ equipped to bear such loads.
My coach once sat for a month with all four wheels off the ground (supported only by the levelers) at a Bounder repair facility with NO problem. The mounting area, of each jack to the frame, actually is much larger than the area attaching the spring shackles. The spring suspension seems to have no problem supporting the coach,
