merleandbabe's avatar
merleandbabe
Tow vehicle battery going dead
Flat towing a 2007 Honda Civic, with no problems except one.
The running lights stay on and the battery goes dead after about two hours.
Any ideas..on how to prevent this? The ignition must stay in accessories potion, and in neutral.
I have heard of a tow charge? How much
Thank you
  • Do you have an electrical pigtail that goes from the coach to the toad .... most coaches do. There should be a "HOT" terminal. From the toad inlet socket run a # 10 wire to the battery using an alligator clamp at the battery side. Also solder in a diode so the power only goes in one direction .... from coach to toad. This will keep the battery charged.
  • I didn't think the lights came on in the "Acc." position. If they do, can you pull a fuse to disable the daytime running lights when towing?
    Lou
    05 Travel Supreme Envoy
    Looks like wa8yxm beat me to it !!!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    What are you using for the aux brake system.. The US-Gear Unified Brake Decelerator system includes a link between the coach battery (Chassis) and the towed, Heavy wire breakerd at 20 amps (Coach) and 40 (Towed).
    Invisible brake (Roadmaster?) also has a charge provision.
    The Towed charge system above with other brake systemns.
    Second, there should be a fuse or two you pull, or you remove the fuse, install a way overpriced adapter (like 50 bucks) with leads and a switch, and plug the fuse into the adapter.. Flip the switch and it cust off the battery killers.
    The running lights should NOT come on in the accessory position.
