- Dale_TravelingExplorer IIHaving only owned a TST base system I can't provide anything regarding how the two compare. Beyond that my one recommendation would be to ensure the tire sensors have owner replaceable batteries. My original TST sensors were sealed and had to be return to TST for credit against purchase of replacements.
- RedRollingRoadbExplorer
RobWNY wrote:
I have the EEZ RV system. It works fine but if you buy that system and your RV is long (I'd say more than 28-30 feet), you better get the extender too. I had a 34 foot 5th wheel and occasionally one of the sensors would stop working. Now that I have a longer 5th wheel, I definately need the extender. The same might be true with the TST 507 system but I have no personal knowledge with that system.
Your experience is the exact same as mine.
My Bounder is 35' and my toad sensors would drop off. The extender solved that. Other than that it has worked fine. - dodge_guyExplorer IIWhen I got my TST I brought the RV home to do some spring maint. I installed the sensors to see how the system worked minus the repeater. The system would intermittently drop the 4 rear sensors for the MH. After I installed the repeater it never drops a sensor even on the toad.
I believe all the sustems now come with the repeater because of customer complaints of sensors dropping out. - billyray50ExplorerFollowing. Just purchased the Bellacorp TPMS system. Will update after real time use for reference.
- stripitExplorerThis RV couple just did a heads up comparisson on two tire monitor systems and posted it on You-Tube, watch and see what they found
Watch here
38,705 PostsLatest Activity: Jan 14, 2025
