jgellis586's avatar
jgellis586
Tripping gfi in garage when plugging into garage
Had motor home plugged into house for over a week then started getting motor home ready for the summer. Flushed water system and noticed water heater was on but did not have water in it. Have everything off but keep Tripping gfi in garage. Was working OK. Can't figure out. Use 15 amp adapter to connect to garage was working. Not sure what is causing it to trip?
  • Update replaced gfci with same result. Next step is to replace the heater element hope to get that next week. Will let u know the result.
    Thanks for all the suggestions.
  • RVs are constantly causing house/garage GFIs to trip. Why? RVs use a different grounding scheme to account for generators, inverters, and other sources of A/C power. Your RV is protected by GFI outlets and you do not need to plug into a protected outlet. Install a power panel (50 amp or 30 amp plugs with no GFI) and nothing will trip. 30 amp is the easiest as it only requires a single breaker and 10 gauge wire to wire to code.
    As an alternate, plug into a non-GFI outlet in your house.
  • Absolutely, we had two 30 AMP RV electrical connections in our garage, but our garage is 37' X 42' with two 18' overhead garage doors. I concur with the poster above me! Bags.
  • Fix the ground fault. The fault is incorrectly using the ground as a conductor.
  • Update have riled out hot water heater element. Took to Tv place and it was ok. I am now thinking that the charger is tripping gfi due to amps required on startup. Disconnected battery and was able to connect with no tripping. Will be taking battery to auto store tomorrow to have them check battery. Rv is only a year old but not sure why battery won't hold charge. Will let u know what I find. It explains how it was working before.
    A ground fault interrupter does not trip due to overcurrent. It trips because of power leaking to ground or otherwise not returning by the neutral line. (A circuit breaker would trip because of excessive current draw.)
    If your charger is tripping the GFI, then the charger is broken and needs repair or replacement.
